AmeriCommerce by Cart.com is a robust B2B e-commerce platform tailored for businesses with complex needs, such as wholesalers, distributors, and multi-store operators.
Subdomain * |
Enter your account subdomain.
OAuth 2.0 client * |
Select the OAuth 2.0 client that stores the client ID and client secret. How to retrieve the client ID and client secret To add an OAuth 2.0 client and configure your credentials, click the plus (+) button. Click the edit ( |
Callback URL * |
Enter the Celigo integrator.io Callback URL. |
Scopes * |
Scopes are OAuth 2.0 permissions that AmeriCommerce by Cart.com defines to limit access to your account. |
Cart.com
Sign in to your Cart.com admin account.
Navigate to Tools > Apps and add-ons > API apps and integrations.
Click New.
Select Scopes.
Click Save.
Copy the App ID (Client ID).
Copy the App secret (Client secret).
Sign in to your AmeriCommerce by Cart.com admin account.
Navigate to Tools > Apps and add-ons > API token manager.
Click App details.
Click New.
Enter an App name.
In Authentication flow > OAuth 2.0 flow, click Select.
Click Finish. You will be redirected to the API token manager page.
Navigate to Apps > Actions.
In the installed app, click Edit.
