Celonis software offers process mining and execution management solutions. It helps organizations analyze and optimize their business processes using data from their IT systems (such as SAP, Oracle, Salesforce, etc.).
API type * |
Choose your Celonis API type:
Intelligence API type |
Domain * |
Enter your Celonis account domain. For example, if your account URL is |
Auth type * |
Select your Celonis API authentication type (Custom, Token, or OAuth2.0). |
App key * |
Enter your Celonis App key. Multiple layers of protection, including AES 256 encryption, are in place to keep your App key safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
API key * |
Enter your Celonis API key. Multiple layers of protection, including AES 256 encryption, are in place to keep your API key safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
OAuth 2.0 client * |
Select the OAuth 2.0 client that stores the client ID and client secret provided to you by Celonis. How to retrieve the client ID and client secret To add an OAuth 2.0 client and configure your credentials, click the plus (+) button. Click the edit ( |
Valid domain names * |
Scopes * |
Scopes are OAuth 2.0 permissions that Celonis defines to limit access to your account. |
Data push API type |
Domain * |
Auth type * |
Select your Celonis API authentication type (Custom or Token). |
Pool ID * |
Enter your Celonis pool ID. |
App key * |
API key * |
Sign in to your Celonis admin account.
Navigate to Profile > Edit profile.
Enter a New API key name.
Click Create API key.
Copy the API key.
Navigate to Admin and settings > Applications.
Click + Add new application.
Select OAuth client.
Enter an application Name.
From Authentication methods, select Client secret basic.
Click Define scopes.
Select the Scopes.
Click Create.
Copy the Client ID.
Copy the Client secret.
Sign in to your Celonis account.
Navigate to Data integrations.
Click the required Data pool.
From the URL, copy the pool ID. For example, if the URL is
https://celigo.us-1.celonis.cloud/data-pool/pool-abc123, thenpool-abc123is your pool ID.
Select Application key.
Enter a Key name.
Click Save.
Copy the App key.
