Qive (formerly known as Arquivei), is aSaaS platform that centralizes and automates fiscal and financial document management for organisations.
API version |
Select your Qive account API version (either v1 or v2). |
Environment * |
Select your Qive account environment type.
Access key * (if the API version chosen is V2) |
Enter your Qive account access key provided by the Qive support team. Multiple layers of protection are in place, including AES 256 encryption, to keep your connection’s key safe. When editing this connection, you must enter this value each time; it is stored only when the connection is saved and never displayed as text. |
API ID * |
Enter your Qive account API ID provided by the Qive support team. |
API key * |
Enter your Qive account API key provided by the Qive support team. Multiple layers of protection are in place, including AES 256 encryption, to keep your connection’s key safe. When editing this connection, you must enter this value each time; it is stored only when the connection is saved and never displayed as text. |
