BigCommerce is a cloud-based, Saas eCommerce platform designed to help businesses build, run, and scale online stores. It supports both B2C (retail) and B2B (wholesale) selling, making it a flexible solution for a variety of merchants.
BigCommerce has upgraded its token authentication mechanism. Users will no longer be able to create storefront tokens after June 30, 2026, and creating a private token is mandatory going forward. Hence, we recommend using Custom authentication while configuring the BigCommerce connection. If you are using Token authentication, we recommend reauthorizing your connection using Custom authentication at the earliest opportunity. For detailed information on how to reauthorize, see Reauthorize your BigCommerce (GraphQL) connection.
Subdomain * |
Enter your BigCommerce store subdomain. |
Auth type * |
Select your BigCommerce account authentication type (Custom or Token). |
Store hash * |
Enter your BigCommerce store hash. |
Channel ID |
Enter your storefront channel ID (default 1). For more information, see Channel IDs. |
Access token * |
Enter your BigCommerce access token. Multiple layers of protection, including AES 256 encryption, are in place to keep your token safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
Scopes * (Only for the Custom authentication) |
Select the required scopes (Private tokens). |
Sign in to your BigCommerce account.
Click View storefront. Your store page will open.
Copy the Subdomain. For example, if your store account URL is
https://celigo.mybigcommerce.com/?ctk=e237, thenceligois the subdomain.
Copy the Store hash. For example, if your account URL is
https://store-ci4bzn8adz.mybigcommerce.com/manage, thenci4bzn8adzis the store hash.
Navigate to Settings > API > Store level API accounts.
Click + Create API account.
From Token type, select V2/V3 API token.
Enter a Name.
You can also retrieve your store hash from the API path. For example, if your API path is
https://api.bigcommerce.com/stores/ci4bzn8adz/v3/, thenci4bzn8adzis the store hash. -
Select the OAuth scopes.
The Storefront API tokens and Storefront API customer impersonation tokens scopes must be set to Manage.
Click Save. The BigCommerce API credentials window opens.
Copy the Access token.
