Set up a connection to Canto
Canto is a digital asset management (DAM) platform. It helps organizations organize, store, manage, and share digital content like images, videos, documents, and other media files in a centralized, searchable library.
Setting
Instructions
Name your connection *
Tenant subdomain *
Enter your Canto account tenant subdomain. For example, if your account URL is https://demo.canto.com/api/v1, then demo is your tenant subdomain.
Region *
Select your Canto account region:
  • AU: if your account URL is https://demo.au.canto.com
  • CA: if your account URL is https://demo.ca.canto.com
  • DE: if your account URL is https://demo.canto.de
  • Global: if your account URL is https://demo.canto.global
  • US: if your account URL is https://demo.canto.com
OAuth 2.0 client *
Select the OAuth 2.0 client that stores the client ID and client secret provided to you by Canto.
To add an OAuth 2.0 client and configure your credentials, click the plus (+) button. Click the edit (pencil.svg) button to modify a selected OAuth 2.0 client. For more information, see Create an OAuth 2.0 iClient resource.
Grant type *
Select your OAuth 2.0 grant type (either Authorization code or Client credentials).
Scopes *
Scopes are OAuth 2.0 permissions that Canto defines to limit access to your account.
  1. Sign in to your Canto account.
  2. Navigate to Settings > Configuration options > API keys.
  3. Click Create API key.
  4. Enter a Name.
  5. Enter the Website.
  6. Enter the Logo URL.
  7. Enter the Celigo integrator.io Redirect URL.
  8. Click Finish.
  9. Copy the App ID (Client ID).
  10. Copy the App secret (Client secret).
Configure scopes
  1. Click Scope.
    – or –
  3. Click Save
Save and authorize
  1. Click Save and authorize to commit your changes, and proceed to sign in with Canto.
  2. After signing in, review the permissions for the integration and click Authorize application.
Additional references
