Install Walmart - NetSuite Product Flow (ItemSpec 5.X)
Install Product flow (Template) from Marketplace
  1. Sign in to the integrator.io account with admin credentials.
  2. In the left menu, select Marketplace.
  3. In the By type field, select Templates.
  4. In the Marketplace search box, enter Walmart – NetSuite Product flow to locate the template.
  5. Select Preview to view details.
  6. Select Install integration.
  7. On the Disclaimer page, review the content and select Proceed to continue. You will then be directed to the page shown in the screenshot.
Connect to Celigo integrator.io (token-based HTTP)
Celigo integrator.io documentation: API guide
A. Set up an HTTP connection
Start establishing an HTTP connection to Celigo integrator.io in either of the following ways:
  • From the Resources menu, select Connections. Then, select + Create connection at the top right.
       – or –
  • While working in a new or existing integration, you can add an application to a flow by selecting Add source or Add destination/lookup.
The Create connection panel opens with required and advanced settings.
B. Describe the general HTTP connection settings
Mode (required): Select Cloud.
C. Provide required HTTP account information
This article is concerned only with the settings needed for the Celigo integrator.io connection. For complete field documentation, see Set up a token-based HTTP connection.
At this point, you’re presented with a series of options for providing HTTP authentication.
Base URI (required): Enter the Celigo base URI:
Media type (required): Select JSON.
Override media type for success responses: Accept the default value, Do not override.
Override media type for error responses: Accept the default value, Do not override.
D. Configure authentication settings
In the Configureauthentication section, select and configure the authentication.
Auth type (required): Select Token.
Token (required): Enter the API token provided to you by the Celigo integrator.io. Multiple layers of protection are in place, including AES 256 encryption, to keep your connection’s API token safe. When editing this connection, you must enter this token again; it is stored only when the connection is saved and never displayed as text.
Send token via (required): Select HTTP header.
Headername (required): Accept the default value, Authorization.
Headerscheme: Select Bearer.
How to retrieve the API token
  1. Sign in to your Celigo integrator.io account.
  2. Navigate to Resources > API tokens.
  3. Select Create API token. The Create API token panel appears.
  4. Enter the token Name.
  5. From Auto purge token, select the time after which the token should be automatically purged from the system.
  6. Select the required Scope, either Full access or Custom. For more information on API tokens, see Managing API tokens and My API basics.
  7. Select Save and close. You will navigate to the API token page.
  8. Select Show token.
  9. Copy the Token.
E. Test the connection
Once you have configured the Celigo integrator.io connection, you have a few options for continuing:
  • Save – select to test the connection, commit the new connection so that it will be available to all integrations for your account
  • Save & close – select to test and save the connection and exit the Create connection panel
  • Close – select to exit without saving any new changes
  • Test connection – select to verify that your new connection is free of errors
Connect to NetSuite
For detailed instructions on setting up the NetSuite connection, refer to Configure & connect to NetSuite.
Connect to Walmart
For detailed instructions on setting up the Walmart connection, refer to Set up a connection to Walmart.
Install Integrator SuiteApp
Once you have successfully configured the Walmart connection, the Install Integrator SuiteApp step verifies and automatically installs the Integrator SuiteApp.
Copy resources now from template zip
Select Install next to Copy resources now from template zip to begin the installation.
