The @key data variable returns the current key name when iterating over an object with #each, or the numeric index when iterating over an array. Use it to output field names, build labeled lists, or reference position within a loop.
Syntax
{{#each field}}{{@key}}{{/each}}
Examples
Return numeric indexes from an array
{{#each array}}{{@key}}{{/each}}
Input:
{ "array": [1, 2, 3, 4] }
Output: 0 1 2 3
When iterating over an array, @key returns the zero-based numeric index of each element regardless of the element's value or type.
Return key names from a nested object
{{#each @root.child}}{{@key}}{{/each}}
Input:
"child": {
"childTitle": "Child Title",
"childBody": "Child Body"
Output:
childTitle childBody
When iterating over an object, @key returns the name of each key rather than a numeric position.
Return all top-level key names from the root object
{{#each @root}}{{@key}}{{/each}}
Input:
"title": "My New Post",
"body": "This is my first post!",
"array": [1, 2, 3, 4],
"message": "This is the message.",
"child": {
Output: title body array message child
Using @root as the #each target iterates over all top-level keys in the context object.
Usage notes
@keyis only available inside a#eachblock. It has no meaning outside of iteration. - When iterating over an array,
@keyreturns the numeric index (starting at0), not the element's value. - When iterating over an object,
@keyreturns the key name as a string. - To retrieve the numeric position of the current element regardless of whether you're iterating over an array or object, use @index data variable instead.
- To access
@keyfrom a parent#eachloop inside a nested#eachblock, use{{@../key}}.
