Available Stibo Systems APIs
When you configure an export, import, other type of flow step using the prebuilt Stibo Systems connector, you can select any of the API operations listed below, organized by API type.
If your API endpoint isn’t listed here, switch the flow step to HTTP mode and configure the endpoint provided in the Stibo Systems API documentation. You can also create a composite endpoint for this application in HTTP mode.
Resource
API endpoint
Export
Import
Authentication controller
Report authentication result
X
Channel controller
Get channel by ID
X
Add channel
X
Data standard controller
Get current generator info by channel ID
X
Get current data standard version by channel ID
X
Add generator info
X
Add data standard version
X
Add business rules
X
Events controller
Get events
X
Acknowledge event manually
X
Packaging hierarchy controller
Get packaging hierarchy IDs by submission ID
X
Get packaging hierarchy by ID
X
Receivers controller
Get client channels
X
Submission controller
Get products
X
Get products per channel
X
Get product IDs by family ID by submission ID
X
Get submission details
X
Get family IDs by submission ID
X
Submit status controller
Submit status
X
Submit status items
X
