Stibo Systems provides master data management (MDM) solutions, specializing in helping organizations unify, govern, and optimize their critical master data across multiple domains.
The Stibo Systems connector is in BETA and may be subject to changes.
API token * |
Enter your Stibo systems API token. Multiple layers of protection, including AES 256 encryption, are in place to keep your API token safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
