SAP Ariba is a cloud-based procurement and supply chain platform that helps businesses manage sourcing, contracts, and supplier collaboration.
After you start the connection, configure it in theCreate connection panel and complete all of the required * authentication settings:
Environment * |
Select your SAP Ariba account environment (Production or Sandbox). |
Data center * |
Select your SAP Ariba account data center. Note
API key * |
Enter your SAP Ariba API key. Multiple layers of protection, including AES 256 encryption, are in place to keep your API key safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
OAuth 2.0 client * |
Select the OAuth 2.0 client that stores the client ID and client secret provided to you by SAP Ariba. To add an OAuth 2.0 client and configure your credentials, click the plus (+) button. Click the edit ( |
Sign in to your SAP Ariba developer account.
Navigate to Manage.
From the available list, select the application. To create a new application, click +. For detailed information on how to create an application and get the API access, see the Approval process.
Copy the Application key (API key).
Copy the OAuth client ID.
Click Actions.
Click Generate OAuth secret.
Read the message and click Submit.
Copy the OAuth client secret.
