Tipalti is a global payables automation platform that streamlines supplier onboarding, invoice processing, mass payments, tax compliance, and financial reconciliation.
Environment * |
Select your Tipalti account environment:
OAuth 2.0 client * |
Select the OAuth 2.0 client that stores the client ID and client secret provided to you by Tipalti. To add an OAuth 2.0 client and configure your credentials, click the plus (+) button. Click the edit ( |
Grant type * |
Select your authorization grant type (PKCE or Client credentials). For detailed information, see Authorization. |
Environment * (This setting is applicable while configuring the iClient) |
Select your Tipalti API account environment:
Scopes * |
Scopes are OAuth 2.0 permissions that Tipalti defines to limit access to your account. |
Sign in to your Tipalti developer account.
In the Create application window, you can create your app either with Client credentials flow or Authorization code flow.
Click Start now. For more information, see Authentication.
Client credentials flow:
Enter an Application name.
Select the required Scopes.
Click Create.
Copy the Client ID.
Copy the Client secret.
Authorization code flow:
Enter Celigo integrator.io Redirect URL.
Click Create.
Copy the Client ID.
