Set up a connection to Google Admin SDK
Google Admin SDK manages users, groups, and directory resources programmatically to automate administrative tasks and integrate Google Workspace management into your apps.
Only your workspace admin can configure this connection.
Setting
Instructions
Name your connection *
Domain *
Enter your Google Admin SDK email domain. For example, if your email ID is xyz@celigo.com, then celigo.com is your domain.
OAuth 2.0 client *
Select the OAuth 2.0 client that stores the client ID and client secret provided to you by Google.
To add an OAuth 2.0 client and configure your credentials, click the plus (+) button. Click the edit (pencil.svg) button to modify a selected OAuth 2.0 client. For more information, see Create an OAuth 2.0 iClient resource
Scopes *
Scopes are OAuth 2.0 permissions that Google defines to limit access to your account.
dataLoad.svg​​ How to configure the scopes
This connector documentation describes only the settings shown for the Simple view. For the corresponding HTTP settings, see the OAuth 2.0 auth universal connector documentation
  1. Sign in to your Google Cloud Console account.
  2. Select your Project.
  3. Navigate to API and services > Enabled APIs and services > + Enable APIs and services.
  4. Search for Google Admin SDK API and click Enable.
  5. Navigate to Credentials > + Create credentials.
  6. Click OAuth client ID.
  7. In Application type, select Web application.
  8. Enter a Name.
  9. Enter the Celigo integrator.io Redirect URL.
  10. Click Create.
  11. Navigate to Data access.
  12. Click Add or remove scopes and select Google Admin SDK scopes.
  13. Navigate to Credentials and click the Application.
  14. Copy the Client ID.
  15. Copy the Cient secret.
  1. Click Scope.
    – or –
  3. Click Save.
Save and authorize
  1. Click Save and authorize to commit your changes and proceed to sign in with Google Admin SDK.
  2. After signing in, review the permissions for the integration and click Allow.
