Before you begin:
MongoDB CDC listener requires a Professional or Enterprise edition. See Celigo platform editions.
You need an existing MongoDB connection, or you can create one during setup. See Set up a connection to MongoDB.
Use Change Data Capture (CDC) to stream inserts, updates, and deletes from MongoDB collections into your flows in near real-time. CDC reads from MongoDB change streams, so changes arrive within seconds rather than waiting for a scheduled run.
Creating a MongoDB CDC listener provides the following benefits:
MongoDB CDC listener delivers updates within seconds, rather than waiting for the next scheduled run.
Reduces MongoDB load by reading the oplog instead of running heavy scheduled queries.
Streams only changes, cutting data transfer and downstream compute.
Uses server-side aggregation pipelines to filter and select fields from specific databases and collections.
Works with Slowly Changing Dimension (SCD) Type 2 history tables without comparing entire tables, and can show before-and-after changes if Change Stream capture is turned on.
Create a listener as the source in an integration flow to capture change data from MongoDB in real time.
Follow these steps to configure a listener that captures change data from MongoDB and connects it to your flow.
In the left navigation, go to Build > Flows > Create flow.
In Flow builder, select Add source and configure details in the new flow step.
In Application, search and select the database connector MongoDB from the list.
In Step type, select Listen for real-time data from source application.
In Name your step, enter a unique name. You can reuse this listener across flows, so a specific name makes it easier to identify in a list.
Optional: In Describe your step, enter a clear and concise description of the flow step to help anyone using this listener in their flows understand its purpose. Keep this description updated as you make changes.
After configuring the step, complete the listener details.
Configure the scope and filters that determine which MongoDB changes your listener captures.
Before configuring the listener, review FAQs – MongoDB listener for change data capture (CDC) for guidance on snapshot modes, cursor behavior, and scope changes.
You can use regular expressions to specify patterns for databases, collections, or fields.
In Connection, select a MongoDB connection from the list. If you don't have a connection, select Create connection at the end of the list and set up a connection to MongoDB.
In Collections, enter a comma-separated list of values to specify which MongoDB collections to listen to.
If you want to listen to collections on the connection database, enter the
collectionnames. -
If you want to listen to collections on databases other than the connection database, enter the full path like
database.collection. -
If you want to listen to multiple collections, enter only
collectionnames for those on the connection database, and the full path likedatabase.collectionfor those on other databases.
For example, enter
users, database2.productswhereusersrepresents a collection on the connection database anddatabase2.productsrepresents theproductscollection on a different database.Tip
If you leave Collections blank, events from all collections on the connection database are captured. Use
collection.exclude.listin Additional properties to ignore specific collections. -
Optional: In Aggregation pipeline, enter a specific flow of operations on databases, collections, or fields based on how you would like to process, transform, and return results. Each successive operation is based on the previous result. You must always specify the full path for collections and fields here.
In Additional properties, enter key-value pairs for databases, collections, or fields that you would like to listen to or not listen to. You must always specify the full path for collections and fields here. Based on your requirements, you can set optional properties, such as:
database.include.list -
database.exclude.list -
collection.exclude.list -
field.exclude.list
For example, if you want to listen to databases other than the connection database, you can set
database.include.list.Default properties:
capture.modedefaults tochange_streams_update_fullandsnapshot.modedefaults tono_data. You can change these default values if required. -
In Fields to include, select which parts of the change event to include in the listener payload. By default, only the
afterfield is selected, but you can reduce payload size and simplify downstream processing by choosing only the fields you need (for example, justafterandopto capture the updated record and operation type). Nested fields can also be included or excluded for more control. -
In Override read preference mode, select an option to override the read operations within the replica set of your MongoDB connection. By default, reads are directed to the primary node for the most up-to-date data, but you can choose other nodes to optimize performance or reduce load on the primary. However, non-primary modes may return slightly stale data due to replication delays. For information on the options, see MongoDB read preference modes.
In Cursor Management, expand the section. This section is hidden when there is no cursor, that is, the listener has never produced/stored a cursor, or the cursor is not available.
Cursor: The cursor shows the last saved position from the most recent listener run. It’s used to resume capturing changes from the source. To reset the cursor, click Reset and then save the listener. This clears the stored cursor and restarts CDC processing. After restart, the behavior depends on the value stored in the
snapshot.modeproperty. For more information, see FAQs – MongoDB listener for change data capture (CDC).
Configure these settings only if your scenario requires them.
In Max wait time, set the maximum time (in seconds) for the listener to wait before sending a batch of events. Typically, events are sent when the page size limit is reached. If the events are fewer, they are sent after the wait time. The default is 300 seconds. The minimum wait time is 30 seconds.
In Page size, specify how many records you want in each page of data. The Celigo platform splits exported data into pages of records. The default is 250 records per page; pages are capped automatically at 5 MB. The application you are importing data into will most often be the bottleneck on page size.
In Data URI template, when your flow runs but has data errors, use this field to ensure that all the errors in your job dashboard have a link to the original data from the export application. This field uses a handlebars template to generate the dynamic links based on the data being exported.
Turn on Do not store retry data if you don't want the Celigo platform to store retry data for records that fail in your flow. Storing retry data can slow down your flow's overall performance if you are processing very large numbers of failing records.
In Override trace key template, define a trace key that the Celigo platform will use to identify a unique record. Any value you provide overrides the default trace key for your app. You can specify a single field, such as
{{record.field1}}, or use a handlebars expression. For example,{{join "_" record.field1 record.field2}}generates a trace key such as123_456. If you have applied a transformation to exported data, reference its fields in the trace key template without the pathrecord.— for example,{{field1}}.
After saving your listener, it appears in the flow builder. Connect it to an import step to begin capturing changes from MongoDB.
