Set up a connection to Jenkins
Jenkins is an open-source automation server that helps developers build, test, and deploy software continuously using customizable pipelines.
Setting
Instructions
Name your connection *
Base URI *
Enter your Jenkins account base URI. For example, if your account URL is https://jenkins.integrator.io/user, then jenkins.integrator.io is your base URI.
Username *
Enter your Jenkins account username (user ID).
dataLoad.svg​​ How to retrieve the username
Password *
Enter your Jenkins account password.
Multiple layers of protection are in place, including AES 256 encryption, to keep your connection’s password safe. When editing this form later, you must enter this password again; it is stored only when the connection is saved and never displayed as text.
This connector documentation describes only the settings shown for the Simple view. For the corresponding HTTP settings, see the Basic auth universal connector documentation.
  1. Sign in to your Jenkins account.
  2. Navigate to Profile.
  3. Copy the User ID (Username).
