Linear is a project management and issue-tracking tool that helps teams plan, track, and manage software development tasks efficiently.
Auth type * |
Select your Linear account authentication type (Token or OAuth 2.0). |
Token authentication |
API token * |
Enter your Linear API key. Multiple layers of protection are in place, including AES 256 encryption, to keep your connection’s key safe. When editing this form later, you must enter this key again; it is stored only when the connection is saved and never displayed as text. |
OAuth 2.0 authentication |
OAuth 2.0 client * |
Select the OAuth 2.0 client that stores the client ID and client secret provided to you by Linear. To add an OAuth 2.0 client and configure your credentials, click the plus (+) button. Click the edit ( |
Scopes * |
Scopes are OAuth 2.0 permissions that Linear defines to limit access to your account. |
Sign in to your Linear account.
Navigate to Profile > Settings > Preferences > Security and access.
In Personal API keys, click New API key.
Enter a Key name.
Select the Permissions and Team access.
Click Create.
Copy the API key.
Navigate to Profile > Settings > Administration > API.
In OAuth applications, click +.
Enter an Application name and Developer name.
Enter the Celigo Redirect URL.
Click Create.
Copy the Client ID.
Copy the Client secret.
Click Scope.
To access all of the scopes in the API, click the » button.
– or –
Click Save.
