AWS Bedrock is a fully managed service that lets you build and scale generative AI applications using foundation models from leading AI providers, without managing infrastructure.
| Setting | Instructions |
| Name your connection * |
Region * |
Select the AWS region. For example, Europe (Paris). |
| Auth type * |
Select one of the following options:
Based on the option you select, associated fields are shown. |
Access key ID * |
Enter your AWS access key ID. |
Secret access key * |
Enter your AWS secret access key. Multiple layers of protection are in place, including AES 256 encryption, to keep your connection’s secret safe. When editing this form later, you must enter this value again; it is stored only for a saved connection. |
AWS iClient * (For IAM role) |
Enter your AWS iClient. How to create the AWS iClient Note that you when you create the AWS iClient, use celigo-http-adaptor- as the prefix in the Role ARN setting. |
Session token (Optional) |
Enter the AWS session token if you are using temporary security credentials (for example, from AWS STS, Federated identity/SSO, or MFA-protected requests). Multiple layers of protection are in place, including AES 256 encryption, to keep your connection’s token safe. When editing this form later, you must enter this value again; it is stored only for a saved connection. |
How to retrieve the access key ID and secret access key
Sign in to your AWS IAM console.
Select the required user.
Navigate to Security credentials.
Click Create access key.
Copy the Access key ID. For detailed information, see Manage access keys for IAM users.
Copy the Access key.
Set up a connection for the AI agent
After you start creating an AI agent and select Bring your own key (BYOK), select an existing connection or create a new one. If you create a new connection, complete all of the required * authentication settings described below:
| Bedrock runtime endpoint * | Enter your Bedrock runtime endpoint. For example, if your account region is us-east-1, enter the endpoint in this format: https://bedrock-runtime.<us-east-1>.amazonaws.com. |
| API key * | Enter the Bedrock API key. For detailed information on retrieving the API key, see API keys. Multiple layers of protection are in place, including AES-256 encryption, to keep your connection’s API key safe. When you edit this form later, you must enter this token again; it is stored only when the connection is saved and is never displayed as text. |
