Google Vault is an information governance and eDiscovery tool that helps organizations retain, search, and export data from Google Workspace apps like Gmail, Drive, and Meet for legal or compliance purposes.
Only your workspace admin can configure this connection. For more information, see Vault privileges.
OAuth 2.0 client * |
Select the OAuth 2.0 client that stores the client ID and client secret provided to you by Google. To add an OAuth 2.0 client and configure your credentials, click the plus (+) button. Click the edit ( |
Scopes * |
Scopes are OAuth 2.0 permissions that Google defines to limit access to your account. |
Sign in to your Google Cloud Console account.
Select your Project.
Navigate to API and services > Enabled APIs and services > + Enable APIs and services.
Search for Google Vault API and click Enable.
Navigate to Credentials > + Create credentials.
Click OAuth client ID.
In Application type, select Web application.
Enter a Name.
Enter the Celigo integrator.io Redirect URL.
Click Create.
Navigate to Data access.
Click Add or remove scopes and select Google Vault scopes.
Navigate to Credentials and click the Application.
Copy the Client ID.
Copy the Cient secret.
