FAQ: Should I reuse a component in another flow?
Connections, imports, exports, and lookups are all stand-alone resource components in integrator.io. Each resource can be used in multiple flows without the need to make a copy of the same object every time. As long as an identical resource meets your needs, simply select it when building a new flow. Keep in mind that if you modify the resource in any way, the changes will impact all flows that use that same resource.
Caution
When you open a shared export, import, lookup, lookup cache, script, AI agent, guardrail, or async helper to edit it, a Proceed with caution banner appears at the top of the editor showing how many places use it. Click Used by in the banner to review all references before saving your changes.
This will use the same instance of the component. If you have multiple users working in your account, Celigo recommends that you create new resource components for each individual flow to avoid making accidental edits to objects used by flows that serve different purposes. Make sure that each new resource component (connection, import, export, or lookup) has a unique name that easily identifies its use and purpose. Always avoid using vague or identical names for these objects.
