BarTender is an enterprise labeling and barcode software that helps organizations design, manage, and automate the printing of labels, barcodes, RFID tags, and documents for manufacturing, warehousing, and compliance needs.
API type * |
Choose your BarTender API type:
API type: Cloud |
Region * |
Select your BarTender account region (America, APAC, or Europe). |
OAuth 2.0 client * |
Select the OAuth 2.0 client that stores the client ID and client secret provided to you by BarTender.
To add an OAuth 2.0 client and configure your credentials, click the plus (+) button. Click the edit ( |
Username * |
Enter your BarTender Cloud username. |
Password * |
Enter your BarTender Cloud password. Multiple layers of protection are in place, including AES 256 encryption, to keep your connection’s password safe. When editing this form later, you must enter this password again; it is stored only when the connection is saved and never displayed as text. |
API type: Print portal (On-premise) |
Agent * |
Select an agent from the list. To connect to an on-premise application, integrator.io requires that an agent be installed on a networked computer. An agent is a small application that allows you to connect to data behind your firewall. When installing an agent, you will specify a unique access token, which then populates the Agent drop-down list. The installed agents connect to integrator.io and establish a reverse SSH tunnel, allowing secure communication without the need to whitelist integrator.io IP addresses in your firewall settings. A single agent can be used by multiple different connections. |
Print portal base URL * |
Enter the BarTender Print portal Base URL. For example, if your print portal is located at |
Username * |
Enter your BarTender Print portal username. |
Password * |
Enter your BarTender Print portal password. Multiple layers of protection are in place, including AES 256 encryption, to keep your connection’s password safe. When editing this form later, you must enter this password again; it is stored only when the connection is saved and never displayed as text. |
Sign in to your BarTender cloud account.
Navigate to Administration> API keys > Web applications (OAuth).
Click Register application for OAuth access.
Enter a Name and Description.
Enter Celigo integrator.io Redirect URL.
Click Register. For detailed information, see Authentication.
From the Applications list, copy the Client ID.
Copy the Client secret.
Click Save and authorize to commit your changes and proceed to sign in with BarTender.
After signing in, review the permissions for the integration and click Accept.
