15Five is a performance management and employee engagement product that helps managers and employees track objectives, do 1-on-1s, share reviews, and give continuous feedback.
After you start the connection, you have to configure it in the Create connection panel and must complete all of the required * authentication settings:
| Setting | Instructions |
| Name your connection * | Enter a clear and distinguishable name. Throughout integrator.io imports and exports, you will have the option to choose this new connection. A unique identifier will prove helpful later when selecting it from a list of the connections in your account. |
| API token * |
Enter your 15Five access token. For detailed information on retrieving the access token, see Generate an API access token in 15Five. Multiple layers of protection, including AES 256 encryption, are in place to keep your access token safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
Tip: This connector documentation describes only the settings shown for the Simple view. For the corresponding HTTP settings, see Token auth universal connector documentation.
