When you configure an export, import, other type of flow step using the prebuilt Front connector, you can select any of the API operations listed below, organized by API type.
If your API endpoint isn’t listed here, switch the flow step to HTTP mode and configure the endpoint provided in the Front API documentation. You can also create a composite endpoint for this application in HTTP mode.
Resource |
API endpoint |
Export |
Import |
Accounts |
List accounts |
X |
Create account |
X |
Fetch an account |
X |
Update account |
X |
Delete an account |
X |
List account contacts |
X |
Add contact to account |
X |
Remove contact from account |
X |
Analytics |
Create a new analytics export |
X |
Fetch an analytics export |
X |
Create a new analytics report |
X |
Fetch an analytics report |
X |
API endpoints |
Sync inbound message |
X |
Sync outbound message |
X |
Update channel |
X |
Update external message status |
X |
Application message templates |
Sync application message template |
X |
Update application message template |
X |
Applications |
Trigger application event |
X |
Attachments |
Download attachment for a comment |
X |
Download attachment |
X |
Download attachment for a message template |
X |
Download attachment for a message |
X |
Channels |
List channels |
X |
Get channel |
X |
Update channel |
X |
Validate channel |
X |
Create a channel |
X |
List teammate channels |
X |
List team channels |
X |
Comments |
Get comment |
X |
Update comment |
X |
List comment mentions |
X |
List conversation comments |
X |
Add comment |
X |
Add comment reply |
X |
Contact handles |
Add contact handle |
X |
Delete contact handle |
X |
Contact lists |
List contact lists |
X |
Create contact list |
X |
Delete contact list |
X |
List contacts in contact list |
X |
Add contacts to contact list |
X |
Remove contacts from contact list |
X |
List teammate contact lists |
X |
Create teammate contact list |
X |
List team contact lists |
X |
Create team contact list |
X |
Contact notes |
List notes |
X |
Add note |
X |
Contacts |
List contacts |
X |
Create contact |
X |
Merge contacts |
X |
Get contact |
X |
Update a contact |
X |
Delete a contact |
X |
List contact conversations |
X |
List teammate contacts |
X |
Create teammate contact |
X |
List team contacts |
X |
Create team contact |
X |
Conversations |
List conversations |
X |
Create discussion conversation |
X |
Search conversations |
X |
Get conversation |
X |
Update conversation |
X |
Update conversation assignee |
X |
List conversation events |
X |
List conversation followers |
X |
Add conversation followers |
X |
Delete conversation followers |
X |
List conversation inboxes |
X |
Add conversation link |
X |
Remove conversation links |
X |
List conversation messages |
X |
Update conversation reminders |
X |
Add conversation tag |
X |
Remove conversation tags |
X |
Custom fields |
List account's custom fields |
X |
List conversation's custom fields |
X |
List contact's custom fields |
X |
List inbox's custom fields |
X |
List link's custom fields |
X |
List teammate's custom fields |
X |
Drafts |
Create draft |
X |
List conversation drafts |
X |
Create draft reply |
X |
Delete draft |
X |
Edit draft |
X |
Events |
List events |
X |
Get event |
X |
Inboxes |
List inboxes |
X |
Create inbox |
X |
Get inbox |
X |
List inbox channels |
X |
List inbox conversations |
X |
List inbox access |
X |
Add inbox access |
X |
Remove inbox access |
X |
List team inboxes |
X |
Create team inbox |
X |
Knowledge bases |
List knowledge bases |
X |
Create a knowledge base |
X |
Get a knowledge base |
X |
Get a knowledge base with content in default locale |
X |
List categories in a knowledge base |
X |
Update knowledge base in default locale |
X |
List articles in a knowledge base |
X |
Get knowledge base content |
X |
Update knowledge base in specified locale |
X |
Get a knowledge base article |
X |
X |
Delete an article |
X |
Get knowledge base article content |
X |
Update article content |
X |
Create article in knowledge base |
X |
Download attachment from an article |
X |
Get knowledge base article with content in specified locale |
X |
Update article content in specified locale |
X |
X |
Get a knowledge base category |
X |
X |
Delete a knowledge base category |
X |
Get knowledge base category content |
X |
Update knowledge base category |
X |
Get knowledge base category with content |
X |
Create knowledge base category |
X |
Update knowledge base category in specified locale |
X |
List articles in a category |
X |
X |
Links |
List links |
X |
Create link |
X |
Get link |
X |
Update a link |
X |
List link conversations |
X |
Message template folders |
List folders |
X |
Create folder |
X |
Get folder |
X |
Update folder |
X |
Delete folder |
X |
Get child folders |
X |
Create child folder |
X |
List teammate folders |
X |
Create teammate folder |
X |
List team folders |
X |
Create team folder |
X |
Message templates |
Get child templates |
X |
Create child template |
X |
List message templates |
X |
Create message template |
X |
Get message template |
X |
Update message template |
X |
Delete message template |
X |
List teammate message templates |
X |
Create teammate message template |
X |
List team message templates |
X |
Create team message template |
X |
Messages |
Receive custom messages |
X |
Create message |
X |
Create message reply |
X |
Import message |
X |
Get message |
X |
Get message seen status |
X |
Mark message seen |
X |
Rules |
List all company rules |
X |
List rules |
X |
Get rule |
X |
List teammate rules |
X |
List team rules |
X |
Shifts |
Get shift |
X |
List shift's teammates |
X |
Add teammates to shift |
X |
Remove teammates from shift |
X |
List shifts |
X |
Create shift |
X |
Update shift |
X |
List teammate shifts |
X |
List team shifts |
X |
Create team shift |
X |
Signatures |
Get signatures |
X |
Update signature |
X |
Delete signature |
X |
List teammate signatures |
X |
Create teammate signature |
X |
List team signatures |
X |
Create team signature |
X |
Statuses |
List company ticket statuses |
X |
Get ticket status |
X |
Tags |
List company tags |
X |
Create company tag |
X |
List tags |
X |
Create tag |
X |
Get tag |
X |
Update a tag |
X |
Delete tag |
X |
List tag children |
X |
Create child tag |
X |
List tagged conversations |
X |
List teammate tags |
X |
Create teammate tag |
X |
List team tags |
X |
Create team tag |
X |
Teammate groups |
List teammate groups |
X |
Create teammate group |
X |
Get teammate group |
X |
Update a teammate group |
X |
Delete teammate group |
X |
List teammate group team inboxes |
X |
Add teammate group team inboxes |
X |
Remove teammate group team inboxes |
X |
List teammate group teammates |
X |
Add teammate group teammates |
X |
Remove teammate group teammates |
X |
List teammate group teams |
X |
Add teammate group teams |
X |
Remove teammate group teams |
X |
Teammates |
List teammates |
X |
Get teammate |
X |
Update teammate |
X |
List assigned conversations |
X |
Teams/Workspaces |
List teams |
X |
Get team |
X |
Add teammates to team |
X |
Remove teammates from team |
X |
Token identity |
API token details |
X |
