Manage guardrails
To see the guardrails in your account, navigate to AI studio → Guardrails.
If you haven’t added any guardrails yet, click Create guardrail to add one.
The guardrails list view displays key information for each guardrail in the respective column. You can manage guardrails using the Actions overflow (...) menu:
  • Edit guardrail: Use the following steps to  edit or update each guardrail:
    • Make the required changes under each section in the Edit guardrail panel and click Save & close.
      • Name your guardrail
      • Description
      • Guardrail type
      • Confidence threshold
      • Categories
  • View audit log: Opens the log for the selected timeframe. Click Download to save the details to a file.
  • Used by: Displays all of its shared locations. Click to navigate to the reference.
  • Clone guardrail: Duplicate a guardrail configuration. You must check the guardrail details and click Clone guardrail.
  • Delete guardrail: Before removing, you will be prompted to confirm deletion.
