Clone imports
Cloning allows you to keep the original import unchanged while modifying a duplicate version of it.
Cloning imports is based on permissions that a user has in an account.
  • If you are the Owner or have Admin or Manage all permissions, you can clone imports.
  • If you have Custom or Monitor all permissions, you cannot clone imports.
To clone an import,
  1. Click Resource > Imports.
  2. In the Imports page, select any import, then click the Actions menu and Clone import.
  3. In the Clone import page, after reviewing the details, click Clone import.
  4. In the Setup page that opens, configure the connection and any other details as required based on the endpoint you're connecting to. See the Connectors section to configure your connection.
After this, you can see the cloned import added to the list. In this way, you or anyone in your account with the required permissions can clone an import.
