Manage your multi-instance flows
A multi-instance flow is a base flow that you configure once and use to generate customized instances. You manage a multi-instance flow's instances, errors, and run history from the base flow's Instances tab. This article covers navigating a multi-instance flow and enabling or disabling base flows and instances.
Prerequisites
You must have Manage permissions on the integration to change a multi-instance flow or its instances.
Navigate your multi-instance flow
After you've configured your base flow and instances, you can view your instances, connection details, and audit logs.
Base flow Instances tab with the instance dashboard
In your Instances tab, you can:
Note: On the Flows page (Build > Flows), the Last run value for a multi-instance base flow is the most recent run of any of its instances. When you sort the Flows page by Last run, base flows are sorted by that value. If a base flow shows no Last run time, or an outdated one, it updates the next time one of its instances runs.
Note: Cloning or pulling an integration doesn't carry a base flow's instances. See Multi-instance flows in the ILM overview.
Enable or disable multi-instance flows
You can enable or disable multi-instance base flows and individual instances. A base flow uses the Test mode and Enabled switch at the top of the flow, and each instance has an Off/On toggle on the Instances tab. Disabling a flow doesn't stop a run that's in progress, but it stops all later scheduled runs. Before you enable or disable a base flow or instance, review how the two settings interact:
  • When a base flow is enabled, you can enable or disable any of its instances.
  • When a base flow is disabled, you can't make changes to any instances.
  • When a base flow is disabled, all its instances are considered disabled, even if they are enabled individually.
  • When a base flow is re-enabled, every previously enabled instance is automatically re-enabled.
Enable and disable controls for a base flow and its instances
