Set up a connection to Auth0
Auth0 is a cloud-based identity and access management (IAM) platform that helps businesses securely authenticate users and manage authorization.
Setting
Instructions
Name your connection *
API type *
Choose your Auth0 account API type:
  • Management: Manage users, roles, permissions, connections, and tenant settings for admin operations, automation, and back-end integrations.
  • My account: Let end users manage their own profile, security settings, and linked accounts to build secure, self-service account management experiences.
Management API type
Tenant domain *
Enter your Auth0 account tenant domain. For example, if your account URL is https://manage.auth0.com/dashboard/dev-6ljhqh2ct4wo15by/, then dev-6ljhqh2ct4wo15by is your tenant domain.
Region *
Select your Auth0 account region (Australia, CA, EU, Japan, UK, or US).
OAuth 2.0 client *
Select the OAuth 2.0 client that stores the client ID and client secret provided to you by Auth0.
To add an OAuth 2.0 client and configure your credentials, click the plus (+) button. Click the edit (pencil.svg) button to modify a selected OAuth 2.0 client. For more information, see Create an OAuth 2.0 iClient resource
Audience *
Enter your Auth0 API audience.
dataLoad.svg​​ How to retrieve the audience
My account API type
Tenant domain *
Region *
OAuth 2.0 client *
Grant type *
Select your OAuth 2.0 grant type (either Authorization code or Authorization code with PKCE).
API audience *
dataLoad.svg​​ How to retrieve the API audience
Scope *
Scopes are OAuth 2.0 permissions that Auth0 defines to limit access to your account.
  1. Sign in to your Auth0 account.
  2. Navigate to Applications > Applications.
  3. Click Create application.
  4. Enter a Name.
  5. Select an Application type.
  6. Click Create.
  7. Navigate to Settings.
  8. Copy the Client ID.
  9. Copy the Client secret.
  2. Navigate to Applications > APIs.
  3. Copy the API audience.
How to configure scopes
  1. Click Scope.
    – or –
    Check the scopes you want to add and click the>button.
  3. Click Save.
Additional references
