integrator.io 2022.R1 maintenance release notes (v8.3.1.0)
Contents
  • What’s new
  • What’s enhanced
  • What’s fixed
What’s new
New vendor-specific EDI template
Celigo integrator․io is now able to export and import electronic data interchange (EDI) definitions for Emery Jensen Distribution EDI 810.
What’s enhanced
Home page + Create flow button
You can now open Flow Builder from the Home page by clicking + Create flow.
Flow steps connecting through an Acumatica cookie-based connection log in and out
API calls made from any flow step (such as an export or import) using Acumatica cookie-based connectors now automatically logs in and out, instead of requiring separate API calls to first log in and another API call to log out.
Download a file exported from AS2
You can now download AS2 export files if they fail to be processed due to parsing errors.
Updated connectors
We’re continuing to improve the built-in API connectors and keep up with the providers’ features and make the settings more intuitive:
  • Amazon Seller Central – Saudi Arabia and Egypt added to EU region
  • Dun & Bradstreet – corrected Industry Data API resource for Standard Code Tables and Location Profiles
  • Freshdesk – delta functionality available for Contacts and Tickets endpoints
  • HubSpot – removed legacy contacts scope
  • Microsoft Office Sharepoint – new Resources endpoints
  • SAP Business ByDesign – new search parameter Expand and endpoint Get outbound deliveries
  • Square – deprecated endpoints removed
  • Shipstation – improved delta exports from List Fulfillment endpoints
What’s fixed
Customer-reported issues resolved
  • Fields that should have been ignored in an import were synced during the flow run
  • Notification emails were failing for addresses that contained extended characters such as Š and č
  • Generating flow reports for 30-day periods could fail to complete
  • PostgreSQL connections with SSL enabled in integrator.io were not succeeding
  • Transforms were removing line breaks
  • Search parameters in ServiceNow lookups were not saving
  • Multiple email notifications were being sent for the same error
