Understand Reverse ETL Data Warehouse Automation from Snowflake
You can use the Reverse ETL, to send data from Snowflake to endpoint applications. This template lets you create exports from Snowflake exports with minimal configuration to other source applications, additional configuration steps may be required. By default, the following apps are supported out-of-the-box to have the entire flow configured. There are 4 endpoints that are supported for the data flow from Snowflake.
  • Snowflake – Hubspot:
    • Get company detail updates
    •  Get contact detail updates
  • Snowflake - NetSuite:
    • Get customer details updates
  • Snowflake - Salesforce:
    • Get account detail updates
  • Snowflake - Zendesk:
    • Get organization detail updates
    • Get user details updates
Features & benefits
  • Stay in compliance by improving data accuracy, minimizing wrong or duplicate records.
  • Efficiently scale operations by automating processes that rely on the Snowflake platform.
  •  Take control of your integrations with tools that let you configure and make mapping changes on the fly.
  • Use data analysis and business intelligence to improve efficiency and streamline everyday operations.
Supported integration flows
The Reverse ETL, Data Warehouse Automation from Snowflake contains flows that you can configure and deploy without coding or IT support. The following templates are from Snowflake to the specified source.
  • Snowflake - HubSpot
