Oracle Fusion Cloud (HCM) is a cloud-based human capital management suite that helps organisations manage HR, recruiting, payroll, talent, and workforce processes in one system for a global workforce.
The Oracle Fusion Cloud (HCM) connector is in BETA and may be subject to changes.
Domain * |
Enter your Oracle Fusion Cloud (HCM) account domain. For example, if your account URL is |
Auth type * |
Select your Oracle Fusion Cloud (HCM) authentication type (Basic or Token). |
Auth type: Basic |
Username * |
Enter your Oracle Fusion Cloud (HCM) username provided to you through email. |
Password * |
Enter your Oracle Fusion Cloud (HCM) password provided to you through email. Multiple layers of protection, including AES 256 encryption, are in place to keep your password safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
Auth type: Token |
Token * |
Enter your Oracle Fusion Cloud (HCM) token. Multiple layers of protection, including AES 256 encryption, are in place to keep your token safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
This connector documentation describes only the settings shown for the Simple view. For the corresponding HTTP settings, see basic universal connector documentation.
