The Celigo platform allows you to capture requests received by a webhook listener within a specified time period. You can then view the logs to verify that the data includes all expected information.
See debug flow steps for information on debug logs for other flow step types.
Use the following steps to review data sent from a webhook:
- Open the flow that contains a listener export step.
- Click Listener to open the Edit listener panel.
Click View debug logs in the upper right corner of the Edit listener panel.
Click Start debug and choose a period of time for the debugger to capture data.
- Perform an action that triggers the sending of data to the webhook listener within the external application.
Select a log to review data received by the webhook listener.
