Edit or view a sync's settings
After creating a Celigo sync, you can easily view or modify its settings at any time. You can adjust the source, destination, or settings as needed. This article shows exactly where those controls live, so you don't have to hunt for them once you're past initial setup.
Edit a sync
View or modify a saved sync's settings at any time. When editing an existing sync, you can add or remove objects or fields and change connections. You cannot change destinations or sources.
  1. Go to Home home-icon.png, and then open the integration containing your sync.
  2. Select the sync name to open the sync dashboard.
  3. Select Sync details from the top of the page.
  4. Use the steps on the left of the page to select the settings you want to change.
Get notified about sync errors and schema drift
Receive an email when a sync encounters an error or detects schema drift. Schema drift alerts are independent of sync error alerts, so you can turn on either or both.
For one sync
  1. From the sync dashboard, select Sync details from the top of the page.
  2. Select Settings from the left side of the page.
  3. In General, for Sync error alerts, select Yes to get an email about errors.
  4. For Schema drift alerts, select Yes to get an email when this sync detects schema drift.
For several syncs in an integration
  1. From the home page, select the integration that contains the syncs.
  2. Select the Notifications tab.
  3. For Sync error alerts, select All syncs or specific syncs.
  4. For Schema drift alerts, select All syncs or specific syncs. When you select All syncs, any individual sync selections are cleared.
For other users
On the Users tab, in the Notifications column, select the notifications icon for a user. Use Add notifications or Edit notifications to set Sync error alerts and Schema drift alerts the same way. Use View notifications to see a user’s current alerts without changing them. Users with Monitor access can view these options but can’t change them.
What the email contains
The platform checks for schema drift every 15 minutes. The email subject is Schema drift: [sync name]. The email lists the most recent changes and links to event logs for the rest. It also notes that the schema drift policy may already have handled some changes.
Run flows or syncs after a sync completes
Start other flows or syncs automatically after a sync completes. You can also select flows from other integrations.
They run after any run type, including scheduled, manual, selective, and full resync runs, as long as the run loaded records. They also run after a failed sync that loaded records. They don’t run if the sync loaded no records or was canceled.
  3. In General, for Next integration flow, select the flows to run after this sync completes.
  4. For Next sync, select the syncs to run after this sync completes.
Both settings are optional. Leave them blank if you don’t want any flows or syncs to run after this sync.
In the run history of a triggered flow, Sync name: [sync name] shows which sync started it. This applies to flows only.
Deleted or inaccessible flow note
If a selected flow is deleted or no longer accessible, its name stays in Next integration flow without a link, and you can’t select it from the list. Users with Manage access can remove it and save the sync. Users with Monitor access can see the name but can’t save changes.
Backfill historical data
Backfill historical data to ensure complete data synchronization.
  2. Select Settings from the left-side of the page.
  3. For Historical data, select a start date to backfill your historical data.
Learn more
