Available Microsoft Power Automate APIs
When you configure an export, import, or other type of flow step using the prebuilt Microsoft Power Automate connector, you can select any of the API operations listed below, organized by API type.
If your API endpoint isn’t listed here, switch the flow step to HTTP mode and configure the endpoint provided in the Microsoft Power Automate API documentation. You can also create a composite endpoint for this application in HTTP mode.
API
Operation
Export
Import
Flows
List flows
X
Get all users with whom a cloud flow is shared
X
Create a cloud flow
X
Update a cloud flow
X
Delete a cloud flow
X
Share a cloud flow
X
Unshare a cloud flow
X
Export flows
X
Import flows
X
