Set up a connection to Digate
Digate is a business intelligence platform that helps brands unify and analyze eCommerce data across China's digital channels
Important: The Digate connector is in BETA and may be subject to changes.
After you start the connection, configure it in the Create connection panel and complete all of the required * authentication settings:
Setting Instructions
Name your connection *
Entity ID * Enter your Digate entity ID.
OAuth 2.0 client *
Select the OAuth 2.0 client that stores the client ID and client secret provided to you by Digate.
To add an OAuth 2.0 client and configure your credentials, click the plus ( + ) button. Click the edit (pencil.svg) button to modify a selected OAuth 2.0 client. For more information, see Create an OAuth 2.0 iClient resource.
Scope *
Scopes are OAuth 2.0 permissions that Digate defines to limit access to your account.
dataLoad.svg​​ How to configure scopes
Tip: This connector documentation describes only the settings shown for the Simple view. For the corresponding HTTP settings, see the OAuth 2.0 auth universal connector documentation.
How to configure the scopes
  1. Click Scope.
  2. To access all of the scopes in the API, click the » button.
    – or –
    Check the scopes you want to add and click the > button.
  3. Click Save.
Additional references
