Set up a connection to Tyro
Tyro is a business banking and payments platform that helps businesses accept payments, manage banking, and access financial services through integrated digital solutions.
The Tyro connector is in BETA and may be subject to changes.
After you start the connection , configure it in the Create connection panel and complete all of the required * authentication settings:
Setting Instructions
Name your connection *
OAuth 2.0 client *
Select the OAuth 2.0 client that stores the client ID and client secret provided to you by Tyro Connect.
To add an OAuth 2.0 client and configure your credentials, click the plus ( + ) button. Click the edit (pencil.svg) button to modify a selected OAuth 2.0 client. For more information, see Create an OAuth 2.0 iClient resource.
Save and authorize
  1. Click Save and authorize to commit your changes and proceed to sign in with Tyro.
  2. After signing in, review the permissions for the integration and click Accept.
Additional references
