Work with files and folders in integrator.io
After uploading files and creating folders in Celigo Storage, you can search for files and folders across your entire account, preview and download files, reorganize content, rename items, clone files, and delete what you no longer need.
You can also automate these file actions — list, search, delete, create folder, delete folder, move, and rename — inside a flow using the Celigo APIs connector. See Set up a connection to Celigo APIs.
For an introduction to Celigo Storage and how it works, see Celigo Storage overview. For instruction on how to build folder hierarchies and upload files, see Create folders and upload files in integrator.io.
Feature availability:
About system folders
In addition to the folders you create, Celigo Storage automatically creates a system folder for each integration and workspace in your account. System folders give non-admin users role-based access to storage.
A system folder’s name is derived from the name of its integration or workspace. Characters that are valid in integration names but invalid in storage names (notably the slash, /) are stripped from the derived name. If two integrations produce the same folder name, or the derived name collides with an existing user-created folder, the system folder’s name is disambiguated with a number appended — for example, NetSuite - Shopify (1). Your user-created folder is never renamed or replaced.
Caution
System folders are managed by the platform — they can’t be moved, copied, or deleted. You can rename one if you have Manage access to its integration. Renaming uses the same dialog and naming rules as any other folder, and the folder ID doesn’t change, so the integration’s File storage tab and the Integration column link still open the same folder.
Search for a file or folder
Find a file or folder using search, sort, and filter options. Search results are role-scoped — results only include files and folders your role gives you access to.
  1. Go to Resources > File storage.
  2. Enter at least three characters in the search bar to automatically display matching files and folders, along with the directory containing each item.
  3. Optionally, sort your results by selecting a column heading and narrow your results using any of the following filters:
    • File type — Select a file type (JSON, CSV, XML, EDI, Spreadsheets, PDFs, Plain Text, Archives, Images, Videos, Audio, Other, or folders only).
    • Last modified — Filter your results by recency (like today, last 7 days, or last 30 days).
  4. To clear the search and return to the previous location, select the X in the search bar.
Download a file or folder
Download a single file, or download a folder and everything inside it as one .zip file. Downloading doesn't change or remove the item from Celigo Storage.
  2. Find the file or folder you want to download. Select Actions next to that item, and then select Download file or Download folder.
Preview a file
To preview a file without downloading it, go to File storage, select the file, and choose Preview. Previewing allows you to confirm the file's contents before moving, copying, or referencing it, without modifying or deleting it from Celigo Storage.
For large files, Celigo Storage displays a partial view alongside the message: Large file — Showing partial view of the file. Download the file to view everything.
To view the large file, select Download to open it on your computer. From the preview window, you can also select Download to save a local copy or Delete to move the file to the recycle bin.
Move a file or folder
Reorganize your content by moving folders or files.
  2. Find the file or folder you want to move. Select Actions  next to that item, and then select Move.
  3. Select the destination folder, and then confirm.
If a file with the same name already exists in that folder, choose one of the following:
  • Replace existing — Overwrite the existing file and update the last modified date.
  • Keep both — Move the new file and append a number to the name (for example, report1.csv).
  • Cancel — Cancel the move for that file.
Rename a file or folder
Renaming a file or folder doesn't break MCP server references or flow references to it. References use stable internal IDs, not display names, so they continue to point to the correct item after a rename.
  2. Find the file or folder you want to rename. Select Actions next to that item, and then select Edit name or Edit folder name.
    Caution
    File and folder names cannot contain reserved or restricted characters (/\<> : " | ? *{ } ^ % ` [ ] ~ #).
  3. Enter the new name, and then select Save.
  • Keep both — Save the renamed file and append a number to the name (for example, report1.csv).
  • Cancel — Cancel the rename of that file.
You can also rename an integration or workspace system folder if you have Manage access to its integration; users with Monitor access don’t see the option. Renaming a system folder doesn’t move it or change what it contains — its internal ID stays the same, so the Integration column link and the integration’s File storage tab still open the same folder. Move, copy, and delete remain unavailable on system folders.
Clone a file
Cloning creates an independent copy of a file in a destination folder you choose. The copy includes the file's contents and description but doesn't share any references with the original — changes to the copy don't affect the source.
  2. Find the file you want to copy (folders cannot be cloned). Select Actions next to that item, and then select Clone (or Copy).
  • Keep both — Create a copy of the file and append a number to the name (for example, report1.csv).
  • Cancel — Cancel the copy of that file.
Delete a file or folder
Move a file or a folder and all of its contents — including all subfolders and files — to the recycle bin.
  2. Find the file or folder you want to delete. Select Actions next to that item, and then select Delete.
  3. Review the confirmation dialog. If any MCP servers, flow exports, or imports reference the item, they're listed here. You can proceed with deletion regardless — deletion is never blocked by references. Review the list so you know what will break before confirming.
  4. Select Delete to confirm.
Deleted items go to the recycle bin and count toward your storage usage until they're purged. To restore a deleted item or permanently purge it, go to Resources > Recycle bin.
What happens to references after deletion
  • MCP server references — The system automatically removes the reference from the MCP server's configuration. The MCP server continues working with its remaining references.
  • Flow references (exports and imports) — References remain in the flow configuration. The flow will fail on its next run. You'll need to update the flow to point to a different resource.
View a resource's metadata and activity
Review which resources reference an item, and everything that has happened to it.
  2. Next to any file or folder, select Actions, and then choose from the following.
    • Used by — Shows which MCP servers, flow exports, or imports reference this item.
    • View activity — Opens the storage activity log filtered to this item, so you can see what happened to it, who did it, and from where. Downloads are recorded, as well as changes. On a folder, this shows activity on the folder itself — creating, renaming, moving, merging, or deleting it — not activity on the files inside it. To see what happened to a file, open View activity on that file. See Celigo Storage activity log.
