Track your lookup cache usage and limits
Lookup cache usage in integrator.io is measured in units: each read or write request your flows make against a lookup cache is one unit, and your subscription sets a monthly unit limit. This article explains what counts as a unit, which plans include lookup cache and their limits, the notifications you receive as you approach the limit, and how to add capacity. Your usage for the month appears on the Subscription page (see Account subscriptions and entitlements overview).
What counts as a unit
  • Read requests – One unit each time a flow reads up to 4 KB from a lookup cache and the key is found. A read that finds no cached value isn't counted.
  • Write requests – One unit each time a flow writes up to 1 KB to a lookup cache.
Reads and writes draw from the same monthly limit in any ratio. Creating or editing a lookup cache configuration doesn't use units; only requests against the cached data do.
Plans and limits
Lookup cache is included on the Professional and Enterprise tiers of the Platform license and on the Premium, Professional, and Enterprise tiers of the Endpoint license. On other plans the feature is off; contact your account team to add it.
License tier Monthly unit limit
Enterprise 100,000,000
Professional 25,000,000
The limits are the same on older and newer pricing models. Separately from the monthly unit limit, each environment has its own storage allocation: a cap on how much data can be cached at one time.
Notifications and add-on capacity
You're notified by email when your usage reaches 80%, 90%, and 100% of the monthly limit, so you can reduce usage or add capacity before requests are affected. On a Professional or Enterprise plan you can buy add-on capacity to keep using lookup cache after the monthly limit is reached; contact your account team.
