Track your DI volume usage
Your integrator.io subscription allows a set number of data ingestion (DI) volume records per month for Celigo sync. DI volume counts the records your syncs load into their destinations. This article explains which records count, how to read your DI volume details on the Subscription page, and what happens when you exceed your entitlement.
What counts toward DI volume
Each record a sync loads into its destination counts once per run, whether it's inserted as a new row or updates an existing one. A run that reloads a full table counts every row it loads, even if only a few rows changed. Records loaded by a run that fails or is canceled still count. Counts reset monthly.
Your entitlement is the DI volume included in your subscription plan plus any add-on DI volume, and it's shared across all your environments. For example, 5M DI volume + 10M add-on DI volume gives you DI volume: 0 of 15M / Month at the start of a month. To see the DI volume in your plan, see Manage your Celigo subscription.
Examples
  • Full extract: A run loads a 200,000-row table. It counts 200,000 records, even if only 50 rows have changed since the last run.
  • Delta extract: The same sync in Delta extract mode loads only the 50 updated rows. It counts 50 records.
  • Failed run: A run loads 10,000 of 50,000 records and then fails. Only the 10,000 loaded records count.
Tip: To use less DI volume, use Delta extract mode so each run loads only updated records. For more information, see Celigo sync overview.
Review your DI volume usage
Your DI volume details show this month's records by sync and your monthly totals for the last 14 months.
  1. Go to Account and select Subscription.
  2. Select View next to DI volume.
The DI volume details show your total for the month, such as Using 34 of 2M / Month, under Current usage and Historical usage:
  • Current usage: Shows how many records each sync loaded this month in your current environment. For each sync, Source and Destination show its connections, and Total shows its record count. Syncs you deleted this month still appear if they loaded records. To see syncs in another environment, select it in the Environment filter. This switches you to that environment. A note under the table shows how many of this month's records came from other environments.
  • Historical usage: Your DI volume for each of the last 14 months, including the current month, for all environments. Usage from shows the date range, and each month shows its Usage and Allocated entitlement. A month that exceeded its entitlement shows a red bar, red usage, and a warning symbol. Hover over that usage to see how far over you went, such as Overage of 8354195.
Active sync limit
Each environment can have one active sync, unless your subscription includes add-on DI volume, which removes the limit. If you try to turn on another sync over the limit, you get an error. To turn on more syncs, turn off an existing sync, or add DI volume: go to Account > Subscription, select Request upgrade, and open a ticket with Celigo Support.
If add-on DI volume is removed from your subscription, the extra syncs are turned off, and the sync that ran most recently stays on in each environment. Turning off a non-production environment also turns off its syncs.
If you exceed your DI volume entitlement
The account owner and administrators are notified in integrator.io and by email when DI volume reaches 90%, 100%, and 150% of your entitlement. Select Review usage in the notification to open your DI volume details.
Caution: If your subscription doesn't allow overage, your syncs are paused when DI volume reaches 100% of your entitlement. A run that's in progress finishes before the pause. Paused syncs don't turn back on automatically, either when your monthly count resets or when your volume is increased, so turn each one back on. If your subscription allows overage, your syncs keep running, and Celigo contacts you about more volume. To raise your entitlement, go to Account > Subscription, select Request upgrade, and open a ticket with Celigo Support.
Tip: If your license expires, all your syncs are turned off. You can delete them, but you can't turn them back on until you renew the license. After renewal, go to Account > Subscription, and then select Reactivate. The syncs that were running before don't turn back on automatically, so turn each one back on.
Related articles
