Deposco is a cloud-based supply chain and omnichannel fulfillment platform that helps retailers, distributors, and 3PLs manage inventory, warehouse operations, orders, and fulfillment across multiple locations and sales channels.
The Deposco connector is in BETA and may be subject to changes.
| Setting | Instructions |
| Name your connection * |
| Region * |
Select your Deposco account region:
| Client ID * | Enter your Deposco client ID. For more information on retrieving your client ID, see Create an application. |
| Client secret * | Enter your Deposco client secret. For more information on retrieving your client secret, see Create an application. Multiple layers of protection are in place, including AES-256 encryption, to keep your connection’s client secret safe. When editing this form later, you must enter this token again; it is stored only when the connection is saved and never displayed as text. |
| Refresh token * |
Enter the Deposco refresh token. For more information on retrieving your refresh token, see Install the application. integrator.io uses the refresh token, client ID, and client secret to request an access token from The refresh token remains valid until the application is updated in the Deposco developer portal. Multiple layers of protection are in place, including AES-256 encryption, to keep your connection’s refresh token safe. When editing this form later, you must enter this token again; it is stored only when the connection is saved and never displayed as text. |
