Together AI is a cloud platform designed for developers to build, train, fine-tune, and run generative AI and open-source large language models.
After you start creating an AI agent and select Bring your own key (BYOK), select an existing connection or create a new one. If you create a new connection, complete all of the required * authentication settings described below:
| Setting | Instructions |
| Name your connection * |
| API key * | Enter the Together AI API key. For detailed information on retrieving the API key, see Create an API key. Multiple layers of protection are in place, including AES-256 encryption, to keep your connection’s API key safe. When you edit this form later, you must enter this token again; it is stored only when the connection is saved and is never displayed as text. |
This connector documentation describes only the settings shown for the Simple view. For the corresponding HTTP settings, see the Token auth universal connector documentation, and in Base URI, enter https://api.together.xyz/v1.
