Set up a connection to Ollama Cloud
Ollama Cloud is a hosted platform that lets developers run large language models through Ollama's API without managing their own GPU infrastructure.
After you start creating an AI agent and select Bring your own key (BYOK), select an existing connection or create a new one. If you create a new connection, complete all of the required * authentication settings described below:
Setting Instructions
Name your connection *
API key * Enter the Ollama Cloud API key. For detailed information on retrieving the API key, see Create an API key.
Multiple layers of protection are in place, including AES-256 encryption, to keep your connection’s API key safe. When you edit this form later, you must enter this token again; it is stored only when the connection is saved and is never displayed as text.
This connector documentation describes only the settings shown for the Simple view. For the corresponding HTTP settings, see the Token auth universal connector documentation, and in Base URI, enter https://ollama.com.
Additional references
