NVIDIA NIM is a set of optimized microservices that let developers deploy and run pretrained AI models for inference across cloud, data center, and workstation environments.
After you start creating an AI agent and select Bring your own key (BYOK), select an existing connection or create a new one. If you create a new connection, complete all of the required * authentication settings described below:
| Setting | Instructions |
| Name your connection * |
| API key * | Enter the NVIDIA NIM API key. For detailed information on retrieving the API key, see Create an API key. Multiple layers of protection are in place, including AES-256 encryption, to keep your connection’s API key safe. When you edit this form later, you must enter this token again; it is stored only when the connection is saved and is never displayed as text. |
This connector documentation describes only the settings shown for the Simple view. For the corresponding HTTP settings, see the Token auth universal connector documentation, and in Base URI, enter https://integrate.api.nvidia.com/v1.
