Set up a connection to CartonCloud
CartonCloud is a cloud-based platform that combines a warehouse management system (WMS) and a transport management system (TMS) to run warehouse and transport operations.
Important: The CartonCloud connector is in BETA and may be subject to changes.
Setting Instructions
Name your connection *
Environment *
Select your CartonCloud account environment. For more information, see Environments.
  • Global: if your account base URL is https://api.cartoncloud.com
  • North America: if your account base URL is https://api.na.cartoncloud.com
Version * Enter the CartonCloud API version, such as 8. For more information on versions, see General.
Tenant ID * Enter your CartonCloud tenant ID. For detailed information on retrieving the tenant ID, see API clients.
OAuth 2.0 client *
Select the OAuth 2.0 client that stores the client ID and client secret provided to you by CartonCloud. For detailed information on retrieving the client credentials, see API clients.
To add an OAuth 2.0 client and configure your credentials, click the plus ( + ) button. Click the edit ( pencil.svg ) button to modify a selected OAuth 2.0 client. For more information, see Create an OAuth 2.0 iClient resource.
Tip: This connector documentation describes only the settings shown for the Simple view. For the corresponding HTTP settings, see the OAuth 2.0 auth universal connector documentation.
Additional reference
