Set up a connection to Brightpearl
Brightpearl is a retail operating system that helps multichannel merchants and wholesalers streamline their operations, automate processes, and plan inventory.
Setting Instructions
Name your connection *
Datacenter * Enter the Brightpearl account datacenter code, such as eu1. The datacenter code is part of your Brightpearl API URL. For example, if your API URL is https://ws-eu1.brightpearl.com/public-api/topfurniture, then eu1 is your datacenter code.
Account ID * Enter your Brightpearl account ID. For example, if your API URL is https://ws-eu1.brightpearl.com/public-api/topfurniture, then topfurniture is your account ID.
OAuth 2.0 client * Select the OAuth 2.0 client that stores your Brightpearl client ID and client secret, or click + to create one. For detailed information on retrieving the client ID and client secret, see OAuth authentication.
Tip: This connector documentation describes only the settings shown for the Simple view. For the corresponding HTTP settings, see the OAuth 2.0 auth universal connector documentation.
Additional reference
