Predibase is a platform to customize and deploy AI models tailored to your use case and data.
| Setting | Instructions |
| Name your connection * |
| Instance * | Enter your Rubrik Security Cloud subdomain. For example, if your URL is https://celigo.my.rubrik.com, enter celigo. |
| OAuth 2.0 client * |
Select the OAuth 2.0 client that stores the client ID and client secret of your Rubrik Security Cloud service account. To create an OAuth 2.0 client, select Create iClient (+) and enter the following:
For detailed information on creating a service account and retrieving the client ID and client secret, see Authentication. Multiple layers of protection, including AES-256 encryption, are in place to keep your client secret safe. When editing this OAuth 2.0 client, you must re-enter this value each time; it is stored only when the client is saved and never displayed as text. |
This connector documentation describes only the settings shown for the Simple view. For the corresponding GraphQL settings, see the GraphQL universal connector documentation.
