Kivra is a platform that delivers digital mail, invoices, and receipts to people and companies inside the service they already use for important documents.
The Kivra connector is in BETA and may be subject to changes.
| Setting | Instructions |
| Name your connection * |
| API type * |
Choose your Kivra API type:
Each API type uses separate client credentials from Kivra. The API version setting appears only for the Tenant and Partner API types. |
| API version | Select the Kivra API version: v1 or v2 for the Tenant API type, or v1 or v3 for the Partner API type. |
| Environment * | Select your Kivra environment: Production or Sandbox. Each environment uses different credentials. |
| OAuth 2.0 client * |
Select the OAuth 2.0 client that stores your Kivra client ID and client secret. To create an OAuth 2.0 client, select Create iClient (+) and enter the following:
To get your client ID and client secret, email Kivra. For detailed information, see Authentication. Multiple layers of protection, including AES-256 encryption, are in place to keep your client secret safe. When editing this OAuth 2.0 client, you must re-enter this value each time; it is stored only when the client is saved and never displayed as text. |
