Set up a connection to TrueContext
TrueContext (formerly ProntoForms) is a field intelligence workflow platform and field service app for mobile data collection.
Setting Instructions
Name your connection *
API key ID * Enter your TrueContext API key ID. For detailed information on retrieving the API key ID, see Create an API key.
API key secret *
Enter your TrueContext API key secret. For detailed information on retrieving the API key secret, see Create an API key.
Multiple layers of protection, including AES-256 encryption, are in place to keep your API key secret safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text.
This connector documentation describes only the settings shown for the Simple view. For the corresponding HTTP settings, see the Basic auth universal connector documentation.
Additional reference
