These terms appear throughout the integration lifecycle management (ILM) documentation and in integrator.io. Each definition links to the article that explains the concept in full.
| Term | Definition |
| Clone | An independent copy of an integration that you can change without affecting the original. See Clone an integration for Integration Lifecycle Management (ILM). |
| Conflict | A competing change between your current integration and the remote integration. See Pull changes from one integration to another. |
| Current | The integration you work in and pull changes into from a remote integration. |
| Merge | The part of a pull that accepts changes from the remote integration and updates resources in the current integration. In ILM, a merge completes a pull. It isn't the create-or-update behavior of an import. See Pull changes from one integration to another. |
| Original (source) | The integration you create a clone from. |
| pageGenerators (PG) | The JSON name for exports in an integration flow. |
| pageProcessors (PP) | The JSON name for imports and lookups in an integration flow. |
| Pull | A comparison of the changes in a remote integration with your current integration, followed by a merge of those changes into the current integration. See Pull changes from one integration to another. |
| Remote | The integration you pull changes from. |
| Resource | Any import, export, flow, script, or other part of an integration. See ILM supported resources and limits. |
| Revert | A rollback of an integration to an earlier revision. See Revert changes. |
| Revision | A snapshot, pull, or revert. See Work with revisions. |
| Sandbox (non-production) | An environment for testing changes before they reach production. See Developing with integration lifecycle management. |
| Snapshot | A copy of an integration's state that you create at any point to use as a backup. See Back up an integration with a snapshot. |
