Workday is an enterprise management cloud platform that provides solutions for finance, HR, spend management, and planning.
Required preparation
To set up a connection to Workday, you must first:
- Create an Integration System User (ISU) user for Celigo in your Workday account. For information on how to create an ISU user, see Workday integration.
- Add the security domains in the Integration System Security Group (ISSG) for Celigo as shown:
After you start the connection, you have to configure it in the Create connection panel and must complete all of the required * authentication settings:
Setting | Instructions | |
Name your connection * | Enter a unique name for your connection so that you can easily reference it from other parts of the application. | |
Tenant ID * | Enter your Workday tenant ID. For example, if your Workday tenant URL is https://impl.workday.com/sample_company/d/home.html , then sample_company is your tenant ID. |
Username * | Enter your ISU username and append @tenant ID . For example, if IN000_Celigo is your username and xyz1234 is your tenant ID, then enter IN000_Celigo@xyz1234 . |
Password * | Enter your ISU login password. |
Tip: This connector documentation describes only the settings shown for the Simple view. For the corresponding HTTP settings, see basic auth universal connector documentation.
