Magento Order Import Error Code: INVALID_KEY_OR_REF
Error on Order Import
Error Message: 'Invalid class reference key 22.'
Reason: Class value 22 is not a valid option.
Resolution:
Make sure the mapping for the Class field is correct and that the id '22' is available to choose on the order record. There is a possibility that some NetSuite script is changing the class value and setting an invalid value.
