Error on Item Export
Error Message: '[EXCEEDED_MAX_FIELD_LENGTH] [The field displayname contained more than the maximum number ( 60 ) of characters allowed.]'
Reason: This occurs during a Reverse Sync.
Resolution:
Displayname is a standard Netsuite Field of the type Free Form text. This error is generated by Netsuite and not by the Celigo Integration App. The solution here would be to shorten the corresponding Magento field value.
