All Celigo flows use the cron style of scheduling. This document describes cron syntax and provides use case examples.
Cron schedules have five positions referenced by five asterisks:
Minute (0-59) |
Hour (0-23) |
Day of the month (1-31) |
Month (1-12) |
Day of the week (0-6) |
Position |
Description |
Minute |
The first position is for the minute. This is in 15 minute intervals since the script that checks the schedule runs every 15 minutes. The interval ranges in an hour are:
Hour |
The second position is the hour of the day. This is expressed in military format 0-23 where 0 is midnight (12 AM) and 23 is 11 PM. If 11,23 is entered, this means the script runs at 11 AM and 11 PM. |
Day |
The third position is the day of the month from 1-31. If 15 is entered, the script only runs on the 15th day of the month. Enter an asterisk (*) to let it run every day. |
Month |
The fourth position specifies the months to run. This is expressed as 1-12, where 1 is January and 12 is December. Enter an asterisk (*) to run the script every month. |
Weekday |
The fifth position is the day of the week. Use MON, TUE, WED, THU, FRI, SAT, SUN to represent each day of the week. Weekdays can also be referenced with the following number system:
Examples:
0 * * ? * *
Every minute -
0 0 * ? * *
Every hour -
0 0 0 * * ?
Every day at 12:00AM -
0 0 0 1 * ?
Every month on the 1st at 12:00 AM
A cron expression can't simultaneously use day (third position) and weekday (fifth position). Enter a question mark (?) for the unused position.
Run on the first 15 minutes of the hour every 11 AM and 11 PM of every day and every month for any day of the week.
0-14 11,23 ? * MON,TUE,WED,THU,FRI,SAT,SUN
Run on the first part of the hour at 5 AM every 15th day of the month.
0-14 5 15 * ?
Run at the bottom of the hour at 1 PM and 5 PM every month only on Mondays, Wednesdays, and Fridays.
30-44 13,17 ? * MON,WED,FRI
Run every 15 minutes everyday.
0-14,15-29,30-44,45-59 * ? * *
or
0-14 12 ? * 0-6
Run at 5 PM on weekdays.
0-14 17 ? * MON-FRI
Run on the first day of the month at 7 AM.
0-14 7 1 * ?
Take the following class to learn more about this topic.
